Frontenac County EMS
TD
Hasting County
Hello All
Does anybody know what system EMS is using,or what the Frequencies are.
TD
mciupa
Canadian DB Admin
Moderator
I'm here a lot
On Fleetnet, using this tower:
Code:
010 A Harrowsmith (HARROW) 141.54000 141.72000 141.93000 142.09500 [COLOR="Red"]142.26000c [/COLOR]142.39500 [COLOR="Blue"]142.59000a [/COLOR]142.99500
and these talkgroups
MOH Kingston CACC Talkgroups
DEC  HEX  Mode   Alpha Tag Description Tag
35184  897  A  KGN CACC CACC  EMS Dispatch
35200  898  A  KGN WEST West  EMS Dispatch
35216  899  A  KGN CENTRE Centre  EMS Dispatch
35232  89a  A  KGN EAST East  EMS Dispatch
35248  89b  A  KGN TAC 1 Tactical 1  EMS-Tac
35264  89c  A  KGN TAC 2 Tactical 2  EMS-Tac
35280  89d  A  KGN TAC 3 Tactical ?  EMS-Tac
35296  89e  A  KGN TAC 4 Tactical 4  EMS-Tac
35312  89f  A  KGN TAC 5 Tactical 5  EMS-Tac
35328  8a0  A  KGN SPARE Spare  EMS Dispatch
35344  8a1  A  KGN TAC 3 Tactical 3  EMS-Tac
Jammin_Jay
They are on the harrowsmith Tower. Which is just north of kingston on hwy 38, on the east side.
The frequencies and talkgroups are the ones that Mciuapa has mentioned.
They are dispatched from Kingston CACC, from a dispatch center in the city.
It covers south eastern Ontario.
You will hear other MOH vehicles from time to time entering the talkgroup from
other districts, mainly patient transfers from Hotel Dieu and KGH.
Also i would keep 150.100 in your scanner. There is radio traffic from time to time on this freq. Sometimes 7-2-x medevac copter
Forts
Ontario, Canada
It's been ages since I had my BCT8 so unfortunately I can't step you thru it... However you should be able to download the manual from Unidens website. You want to set it up as a VHF Motorola Type II system. You will need the frequencies listed above as well as the base, step and offset (available on the Fleetnet database page).
Forts
Ontario, Canada
Yes, the 'dec' column is the talkgroup ID (in decimal format). I believe the BCT8 may only accept one base frequency, so just put in the first one listed. Directions should be in the manual.
davidmc36
South East Ontario
Page 45 of the manual gives it step by step. Just follow in exact order what it says. You should see on your scanner the examples that the manual shows, except you will put in the particular Base, Space, and Offset numbers required for Fleetnet. When you get done the first set it should change to a little "2" at the top of the scanner display and be ready for the next set, and then the third after that. But as Forts says, you only need the first set. There are only one or two towers or something like that where they have a need for the second, but there is no harm in putting in all three if you choose.
(Isn't it Mowat in Zone 1 that has one or two frequencies that need the second set??)
travis2155
kingston
Ok thanks for all your help. When i hit the trunk button and trunk appears on the top of the screen I don't pick any thing up. I have to leave it off then I get a lot of noise but I can here the talk too. Do i have something set wrong? Any suggestions?
davidmc36
South East Ontario
Do you get the noise on 142.6 or 142.59? And then do you have to make it scan to hear some voice traffic? If so it would sound like you have something not set right and it is not getting the Control Channel when in trunk mode and you are only able to scan in conventional. In that case you hear the data noise when it stops on that frequency.
Or do you hear the voice traffic but with a lot of static when in conventional and get nothing when in trunk mode? If that is the case then maybe you are not getting good enough signal for the scanner to lock on to the Control
Channel when in trunk mode, hence you hear nothing because it is not tracking it. Maybe you need a better antenna.
Eastern Ontario
In Zone 2, the second table entry is required only in the extreme Southeastern corner of the region.
The Vankleek Hill (VANKLK) tower uses 152.000 for one of its voice frequencies.
davidmc36
South East Ontario
Hey I never noticed that before. Will have to check my radios to see if that is programmed in.
