KI5EDJ
WRDB542
Good evening. I'll start with a couple of acknowledgements. First, I'm aware that modifying an FRS radio in any way may result in it not being able to legally transmit anymore. Second, I'm also aware that this radio is not worth fixing from a financial standpoint.
That said, if I'm able to troubleshoot it accurately, I can probably learn something.
I have a "Motorola" EM1000 GMRS radio built by some company called Giant back in 2010. It's a one owner radio that, over it's life, was subject to extreme heat and abuse daily. I often charged it via USB in my truck in the Oklahoma summer heat.
Actually I had *four* of those. One vanished and the other two work fine. Of those, one suffered the same abuse. The last one was barely used at all. It works but I had to re glue the rubber antenna cover to the body.
Anyway, what I think happened here is that several capacitors burst inside this radio. It receives just fine but transmits about ten feet. I haven't tried to transmit anything with it in over a decade but I have used the weather receiver.
There is brown goo running out of a couple of caps and it's stuck several of them together near the antenna. The forums don't like my photo, file size too large so we don't see the big picture here.
