Yaesu: FT5DR programming cable
jazzboypro
Laval
Hello all,
was looking at FT5DR I can't believe that there are so many cables to buy and that they still use a DSUB9 connector to connect to the computer. This is very disappointing considering that it is a brand new product and their flagship handheld. For those of you who have one, are you using a DSUB9 to USB adapter ? I have no DSUB9 connector on my laptop and the one on my PC is located in the back and i'm not sure their cable would be long enough.
73
VA2FCS
ko6jw_2
Santa Ynez, CA
I believe that the cable is required for firmware updates. DSUB9 to USB cables are very common so I don't quite understand the problem. I have some long ones that came with USB mics. I think that the Japanese can be very conservative.about design changes. Sometimes it is frustrating. Also remember that the connector on the radio has a multi-position slide switch under it. A smaller connector might not allow for this switch.
jazzboypro
Laval
Thanks for the info but i think i'll wait and think about it some more, i'm trying to like Yaesu's line of handheld but i just don't for now lol
ko6jw_2
Santa Ynez, CA
Considering that you will use that connector very rarely, it hardly seems like a deal breaker.
jazzboypro
Laval
It's not just the cable, i've looked at a few videos reviewing them and honestly they are too small for my taste. I know it's a matter of taste but they look kind of cheap to me. The reviews are not stellar to say the least. I already have a TH-D74 and ID-52 that takes care of the analog part plus D-STAR and an AnyTone 878 for DMR and analog also. I just need the fusion part of the yaesu. maybe a cheaper model would be just fine. In the mean time i'm using cross mode from the ID-52 and it works fine for now.
vagrant
ker-muhj-uhn
California
For programming the FT5DR I would just do it via the MicroSD card as previously noted. If I wanted a USB programming cable, the one sold by RTSystems is $30. That same USB-68 cable also works with the Yaesu FT1, FT2, and FT3 handhelds. I own one and use it for Wires-X instead of purchasing the more expensive one from Yaesu. I think I may have used it for programming once, but typically just read/write the MicroSD card directly.
I own the FT2 and FT3 and they work fine for me. The FT2 is used as a node when traveling and I carry the FT3. I too have the D74A and use the BTech 6x2, which I think is similar to the 878. DMR is pretty dead around here though.
jazzboypro
Laval
There is a bit of everything over here so it's pretty interesting. I've been using cross mode for a good part of the evening (dstar to C4FM) and it works very well so i may keep it like that for a while. Now i need multiple hotspots so i can listen to all modes at the same time lol
ohiogator
Darke County, Ohio
I once had a radio for every digital mode. Now I have all icom radios and cross mode DStar over to DMR and C4FM. Much easier and cheaper that way IMO. Openspot 3 makes it painless and everything is done on the radio.
jazzboypro
Laval
That is what i'm doing for now, i'm using an icom radio for C4FM and i have a 878 for DMR. The only problem is that i can't simultaneously listen to all modes with only one hospot. I'm thinking of buying a second hotspot. I could connect my 9700 to the main D-STAR reflector that we use the most over RF, use one hotspot for DMR and the other hotspot for C4FM. I already have 3 handhelds that can do analog+dstar/DMR i don't really need a fourth handheld just for C4FM
ohiogator
Darke County, Ohio
Well if you got the ft5, you could drop the 878. You can monitor 2 hotspots at the same time with the ft5. Or ft3, id51, id52 etc.
