jazzboypro
Hello all,
I have installed the latest version of wsjt-x on my laptop. I use it to control my 9700 connected to a GP-3 antenna. Reception is very good and i get lots of decodes in the band activity window. I have not been able to make a QSO so far. I know wsjt can put the radio in tx mode, FT8 (on 2 meter) is the selected mode. the radio is set to USB (also tried USB-D) I've check PSK Reporter web site and it looks like my signal has never been heard.
While transmitting i monitor with my 8600 connected to a discone antenna. The 8600 does pick something up when i transmit so i assume my signal is going out. I tried transmitting at different power levels but still no answers to my CQ's and still no signal on my part seen by PSK reporter web site.
Now, as a test, i am running a second instance of wjst to control the 8600. So now i have both instances decoding FT8 at 144.174. Both radios are decoding the same messages at the same time. I was kind of expecting to see ma decoded message on the 8600 while transmitting on the 9700 but it's not the case. The sending and receiving antennas are about 25 feet appart i don't understand how my own signal is not decoded. I tried a different power levers but to no avail.
I have read the wsft user manual and watched a few videos and to the best of my knowledge everything is configured correctly. There is even a YT video on setting UP the 9700 for use with wsjt. I followed the video exactly but again i kind of have a feeling that something is wrong.
Any suggestions ?
Many thanks
73
De VA2FCS
Any suggestions ?
Many thanks
73
De VA2FCS
