G3/G5 False Out Of Range Indication
RadioDitch
Signals Identification Member
All over the map.
Since the upgrade to 1.3 Firmware several of us have been receiving false out of range indications. Including the administrator of the local system. The units will suddenly alert out of range, despite being line of sight of the tower with zero obstructive terrain, the site information being 100% correct, and an RSSI in the area of -45 or better. In fact, this has happened on both of my units on multiple systems in multiple areas in two countries since the firmware upgrade.
And only since the firmware upgrade. The units have not been modified or damaged in any way. The firmware upgrade is the only change.
Is this a known issue pending correction?
blackbelter
I have not experienced "Out of Range" notification, however after the change over to 1.3, my G5 takes longer to obtain the TT. Under 1.2 the pager locked into the TT almost immediately.
bep
Virginia Beach, Va.
Now that you mention it, mine is going in and out of range a good bit. Thought it was my "wonderful" city system.
IAmSixNine
Dallas, TX
I have several G4 and all are operating normally on V1.3 I do get the out of range indication but its in the same spots as it did with V1.2 and all are a result of being in close proximity to a cell tower with Verizon 700 LTE on it.
RadioDitch
All over the map.
That was a thought of mine back in Jersey, however there is no Verizon or 700MHz LTE up here at work. All there is in town is Rogers and 4G service on higher frequencies on a single tower, which is pretty low power since the coverage area is only slightly over 3sqmi being that's the extent of the amassed human population in the area.
Thunderknight
Bletchley Park
I have not noticed the out of range since upgrading, but I have noticed it seems to takes longer to get the CC and play my voice announcement for that zone.
blackbelter
That’s been exactly my experience as well .I realize that running back and cancelling a FW is a quick resolution however I trust that Unication should come up with some patches to remedy some of these shortcomings specifically not hearing the CC immediately .
ffexpCP
wizard of odd
Michigan
Meh. Going out of range is nothing new for these things. I can see the tower and mine goes out of range often.
dbodette
Wauseon, OH
Exactly the same issue. Updated to 1.3 and now Out of Range all the time. I can see the tower out my back door! Before this it was solid. Something is wrong here. Hope they find a fix. Can I go back to 1.2?
dbodette
Wauseon, OH
After further experimenting I found that if I connect the radio to an external multi-band scanner antenna mounted on my roof, the radio has two bars of signal strength and stays in range. On the rubber duck antenna, standing outside, broken reception, in and out of range (mostly out). It's almost like they have put an attenuator in the programming, reducing the input signal. JMHO
jonwienke
More Info Coming Soon!
VA
I'm running the 1.4 beta firmware head to head vs a SDS100 and haven't had any out of range notifications anywhere the SDS100 was still getting a signal.
trido
Southern In
I just messaged jack on this and he says uni not aware of this issue he needs someone with issue run the log file tool so they can look it over.
hope link works
If in your field test process occurs any issues or problems, please download below "Log Extraction" utility, connect the pager with PC, it can be export your testing pager internal software trace files and upload to Unicaton data server then notify the engineering team. (you can see the attached "Log Extraction User Guide")
Unication Log Extraction Utility
picscan
CA
Mine does it frequently too, the other night it did it and I turned off the top bluetooth, bottom one was already off and it came back instantly, coincidence?
rr60
@RadioDitch the pair of G5’s on 1.3 at my home location when stationary never go out of range. I am line of sight to two NJICS systems and several County 700 System’s.
However, both randomly go out of range when in car and VERY near a cellular tower that has 700 LTE.
This occurs only when monitoring PS 700 LSM systems. The cellular must desense or scramble bits raising BER has been my guess. This has been happening since day 1 for me.
This may be different from what you describe.
