G4 issue
Petertherock
Tampa Bay, FL
This is happening at random times, when my radio is on…it will turn off and on again on it’s own. I am never looking at it when it turns off…the only way I know it’s happened is I get the “Trunking talk group, normal scan” voice prompt when it comes back on. Anyone know what’s going on?
TIA!
w2lie
New York DB Admin
Long Island, NY
Are you using FW 1.33 ? If not, visit the Unication website and apply the latest FW to the pager.
If you have the latest FW, does it happen on non-trunking systems? Are you monitoring a Motorola or Harris P25 system?
BabaDude77
Connecticut
I have noticed this will happen occasionally with my G4 when in monitor mode or ALLCALL and I am trying to find new TGs. The system I have had it happen on happens to be fairly busy so I believe it’s the unit getting overwhelmed with too much traffic at once. It doesn’t seem to happen when I’m not in trunking TG scan mode. Another strange thing I have noticed while listening to my local Harris P25 system after any form of traffic for a second after the transmission is over the signal bar goes to none then comes right back to full strength. It doesn’t seem to effect the way the unit receives or works just seems kinda weird.
Petertherock
Tampa Bay, FL
Just upgraded the firmware. We will see if that was the problem.
llzel
Does it have the reboot dots...............? If so, are you monitoring a system that has both 700/800 and VHF control channels? If yes, the G4 is only 700/800 and it locks up some times. You need to get unication to send you the beta software to fix.
