G4 P25 trunked system
llzel
my ongoing saga continues. was away for a week with G4 in charger. Turned on yesterday and the 3 knob positions i use for one system says out of range on all 3 knob positions. Which makes sense since they all using the same Site and control channels. Prior, I had full signal and I'm well within range. Any ideas on what to do? Other systems continue to work well.
ECFD
KEA536
What firmware? There’ve been complaints of false out of range alerts with FW 1.31.
llzel
I updated to 1.31 several weeks ago without issues. The system is MOSWIN and RR data base still shows same site and RFSS
IAmSixNine
Dallas, TX
Do you have alternate CC channels programmed in? While Moto systems dont often change they will and if you dont have the alternate CC it will not work.
JD21960
ILL-annoyed
Usually "out of range" on Unication pagers means the thing was programmed wrong (System ID, WACN, wrong SITE #) OR ... you actually ARE out of range of the nearest Control channels.
llzel
Thanks for the reply. I never changed programming and it has been receiving for several months. Other than my rebooting issues on that system, it has worked fine. Went on vacation came home, pulled from charger, turned on and showed scanning than out of range. I'm well in range.
jonwienke
More Info Coming Soon!
VA
I would use another radio to confirm whether ther is a signal on the programmed frequencies. If there is, and the G4 isn't seeing them, then it probably got zapped by a power surge while you were gone, and needs repair.
llzel
Someone in state forum confirmed they changed the control channel. Thanks for the responses.
llzel
As some know, my G4 has had rebooting issues with one system. From my office I used to have full bars and occasional rebooting. I now changed the control channel and have only 2 bars and almost constant rebooting on that system. Doesn't make sense but it's happening.
