G5 TG Audio Delay
CanesFan95
Analog already is interoperable.
FL
If I hold on a P25 trunked TG and listen, the audio comes out later than when I monitor the same TG on DSD+. What would cause about a 1-2 second delay in the audio coming through? Is there a setting?
hazrat8990
Wyoming
You have voice buffering turned on. You can turn it off from the settings on the pager, or with PPS. You will get a popup warning, but just ignore it and click ok.
CanesFan95
FL
Got it. Well, that warning pop-up says it'll cutoff the beginning of transmissions:
So I think I need to do this on every TG?
CanesFan95
FL
Also, is there an easy way to turn off voice buffering for every zone/knob position all in one shot without having to go in and out of each one?
hazrat8990
Wyoming
All of the TG's should be set to tone and none anyway. If you have a more than 50 or so TG's to modify, you can speed up the process by exporting to a .csv first. You can then edit the first TG in the row and highlight the changes, and then fill down. Once that's done, just import it back into PPS.
CanesFan95
FL
Ah, bummer about the knob. Yeah you're right, I did figure out the export/import thing with the .csv's and it worked good. But with over 40 zones, I've got some work to do. o_O
Thanks for the replies.
CanesFan95
FL
Actually, I think there's another problem. When you import from the .csv, you have to decide whether or not to delete the old data:
If you do check the box, then your zones get an error and you'll have to go and re-add your TGs to your Talk Group List in every knob position:
If you don't check the box, the import just adds all the TG data to the end of the TGID List in tab E2 and you get everything duplicated. I had 684 TGs, now I have 1,368:
Using multi-select to delete the old ones:
Results in the same knob position errors. :eek:
CanesFan95
FL
I've been testing this out by doing a side-by-side comparison with DSD+ Fast Lane. There's a number of times where the G5 will miss the first part of a transmission that came through on DSD+ regardless of whether Voice Buffering is on or off. Many times I'll hear the whole transmission on DSD+, but the first word or 2 is missed on the G5. Setting the Alert Mode to Tone or None and Alert Tone to None makes no difference no matter which way you set it.
This is concerning. If anything, you would think it would be best to set Alert Mode to None so there's no chance of a delay or chop-off, despite that warning prompt. Why would that prompt tell us to set it to Tone if we want no tone at all and no chance of a clipped transmission? I also don't understand what the prompt is talking about where it fers to this "Private Call ID Setting". I'm not seeing that anywhere. Doesn't make sense. But like I said, I still get delayed unmutes on the G5 compared to DSD+ when holding on the same TG no matter what setting.
jtwalker
Gettysburg, PA & Fenwick Island, DE
Initially you asked about a delay and now you are talking about missing the beginning of transmission. I believe voice buffering will cause both of these, with it being on to cause one and off to cause the other. Not sure, but this is my understanding.
hazrat8990
Wyoming
Which version of firmware are you running? Lots of folks with older pagers that have upgraded firmware to V2.0+ have experienced issues.
CanesFan95
FL
Firmware 2.02, bought the pager a little over a year ago.
hazrat8990
Wyoming
If the hardware has the new chipset it will have an "N" in the model number and also show G5N on tab E1 on PPS. If it has the older chipset, you will most likely get rid of your issues by downgrading to V1.35 as many others have done.
IAmSixNine
Dallas, TX
Can confirm that my G4 pagers on V1.33 and V1.35 with voice buffering on and 3 with it off, do not miss calls. Nor do i miss the first few seconds. Tested against SDS100, KNG2-P800, APX and on multiple different systems.
Your issue might be with V2xx software.
FishScan
Rebuild your programming file using the 4.0 PPS. You have too much redundant information bogging down your pager.
ErikSwan
Boise, Idaho
Yep, it's a massive pain when you are trying to update talkgroup information. I haven't found a way around that yet. There is probably a way to manually edit the saved profile on disk without using PPS, but I haven't had the time to investigate what format it is in.
