G5 UHF Performance
WX4JCW
Stow, Ohio
I was actually pretty surprised how well this radio does on UHF, I’m a good bit away from the repeaters and it’s clear as a bell
mshumeyk
Southern New Jersey Shore
I was going to add that if you add the CTCSS or DPL you can get rid of the squelch tails (if you so desire) but a quick check shows me the LACFD Blue channels are mainly CSQ. I have a G3 and G5 here on the East Coast and have been very pleased with their performance on VHF-Hi, 400Mhz and 700-800mHz on both digital and analog. Portability, durability, battery life and clear audio in high noise environments are some of my favorite qualities of these units. I especially like the ability on the tone outs to to record and instantly play back the dispatch I might have missed. Certainly the Unications lack the versatility of regular scanners (of which I have several) but my Unications are my choice for on the go monitoring and for Tone Dispatch Alerting when not actively monitoring.
blackbelter
Using my G5 ( Blue banded supplied stubby antenna), I monitor a small UHF , DMR system with great sounds and decoding.
WX4JCW
Stow, Ohio
It doesn’t use the stubby for VHF/UHF from what I gather it uses an internal antenna or did they change it?
mshumeyk
On the G5 the blue stubby is for 700-800 band reception, while there is an internal antenna for VHF high.
On the G3 the green stubby is for 400 band (UHF) reception and the VHF high band is via the internal antenna.
WX4JCW
Stow, Ohio
sadly, it's better than that sds 200 with an outboard antenna.
I have a SDS200 with one of the Larsen Tri Banders, it’s not that bad, I listen to Rail a lot and it works pretty well, but it’s a scanner, it’ll never outdo a dedicated commercial radio in most cases
blackbelter
I merely mentioned the blue banded antenna to forward the effectiveness of the G5 internal antenna. I realize that G5 uses internal antenna for the UHF /VHF bands.
Thanks,
WX4JCW
Stow, Ohio
Thanks,
Its all good, I asked because I wasn’t sure
