GE UHF RADIO
radsmachine
Mississippi
Does anyone know anything about the Ericsson GE AXATR-198-A5 ?
I have two and can't find anything about them. I'd like to know how to program them.
bobsmr
This should get you started.
Called MDS by GE, but not the same as GE MDS 900MHz point-to-point product of the same name.
I have documentation, but it's also on repeater-builder.com in Master LBI listing.
Just use find to search for MDS.
There is a VHF model also.
Been a long time since I programmed one, but have the stuff somewhere.
Will look soon.
Bob
radsmachine
Mississippi
Any other info would be greatly appreciated. And If you have a cable or software perhaps you'd consider loaning or selling?
N5IDK, Rich. Soso, MS
merlin
DN32su
What you have supplied is the FCC ID number. A bit useless for answering your questions.
There should be a model number of sort on the tag or if you can post a photo of the radios and tags, I have a huge stockpile of GE documentation and software to help you.
bobsmr
I'll dig around and see what I can find.
Many of those older GE style radios used a special connector (mic plug usually) to the radio through the TQ3310 program interface box.
I don't know what your technical capabilities are, but if you are a ham you should be able to brew up the cable if required.
If you have little/no technical capabilities, then looking up all the information serves little purpose.
What say you?
merlin
DN32su
As is typical for GE, MaCom, Ericsson, and Harris, there is no one service manual. They are spread across several hundred files with obscure names.
Without at least a product number, you are not going to find needed information for a particular type of radio.
Programming boils down to 1 of 3 softwares needed, but cables are specific to radio types/classes, M RK, MDX, Orion class. OMAP class, Unity class. so ??????????
