ka3jjz
Wiki Admin Emeritus
These comments were posted in the wiki recently (re the message in the wiki forum)
Bold textTo FEED PROVIDER: I worked in Coweta County and dealt with CCSO & NPD. I noticed that you asked for any comments so I figured I would help you out and some of this you might know but just in case, Coweta County Sheriff freq. is 151.1300. Newnan Police has a shared frequency. If your in or close to Newnan, then shouldnt have any problems. The freq. is 155.6850 which is also Jackson PD (Butts Co.)To prevent any confusion, I just programmed the CTCSS code. Also the same is with Coweta County Fire which is 154.2050 and Newton County's Fire Pagers are the same. And again I programmed the CTCSS code in to stop any unwanted transmission. Hope this helps and good Luck and thank you for providing.
(User is GA184)
Hi,
I really miss the feed...any idea when it will be back online?
Thanks for having it out there!
Greg
(User is gdyer)
73 Mike
[edit] Oops, my bad - cross posted, which is a no-no...
(User is GA184)
Hi,
Greg
(User is gdyer)
73 Mike
