Getting stuck on ID's after transmission.
howie38
Pemberton NJ
Recently on my Burlington County 'North West Central' band, after a transmission it stays on that ID with static that I can't squelch out.
I have to hit scan or it will move on by itself in a minute. Seems to only do it on the N-C-W MU2, but all settings are the same with the other MU2s
howie38
Pemberton NJ
Review the "End Code" settings here:
Uniden BCD96P2 Owner's Manual (Page 51 of 112) | ManualsLib
Also confirm you have the latest firmware.
Good luck!
Actually, it started after the latest update. Tried it with the end code off, didn't make any difference. It's not consistent, just now and then. And only on the N-C-W. Transmissions on all the other areas of the county doesn't give me any trouble and all of them have the same identical settings.
howie38
Pemberton NJ
Just an update. Tried to play around with the "threshold" settings. That didn't work so well, but I noticed that when I received the same talkgroups on 'North' it wouldn't do it. So I just locked out those groups on 'North Central West'.
howie38
Pemberton NJ
Looks like I solved the problem by setting the 'delay' time to -10.
Must force it to restart scanning, instead of me hitting the button after each transmision.
Ubbe
Stockholm, Sweden
It seems as if the system doesn't send any end tone, or the new firmware doesn't handle it anymore. As the squelch doesn't close, it is probably some sort of interference so you could try the IFX setting on that particular voice frequency, if it is the same frequency that always hangs.
/Ubbe
