Good Scanner for VHF
Colin9690
Delaware County, OH
Lewis Center, OH
Hey everyone, I'm looking to purchase a scanner off eBay for the sole purpose of receiving VHF (namely air-band and railroad).
Just looking for something that really pulls in VHF well, it can be new, or old. What radio do you guys have, or have owned, that excels on that band?
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Base or portable? Consider the Uniden BCT-15X (base) or BC125AT (portable). Also the antenna you have connected makes a world of difference too so be sure to ditch the stock antenna and upgrade. I've had good luck with the Comet W100RX but an external antenna mounted high above your roof line will do wonders to pull signals in, particularly VHF
Listen365
BC125AT is excellent because of the alpha tags. Agree on external antenna. Have you checked out Train Aficionado on YouTube? The Scanner Guys have a show tonight at 8pm eastern time.
ko6jw_2
Santa Ynez, CA
Radio recommendations are very good. However, no matter how good the radio is, it is only as good as your antenna and feed line. Antenna requirements for good aircraft reception are not the same as those for railroads. Aircraft requires wide bandwidth and a high angle of radiation whereas railroad is in a fairly narrow frequency range but needs a low angle of radiation (gain). Aircraft will be mostly line of sight up in the air. Not so with railroads.
Ubbe
Stockholm, Sweden
If they are line of sight you can receive them with almost any kind of antenna. It's when aircrafts are a long distance away that they are harder to hear and will be located at the horizon and will require a high gain antenna that receives mostly from a low elevation angle at the horizon, the same as for railroad.
/Ubbe
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Literally any scanner you can buy these days will receive just as well as any. I'd focus more on what features you want in a scanner, and what future uses you might see yourself using it for. And as others have said, antenna and coax(feedline) are more important. But for casual use at a stock antenna will do fine too. No need to ditch the factory antenna if it's meeting your needs.
p1879
Guys are right about the BC125. Mine has also survived hard drops dozens of times, with the the batteries being hurled out many times. I think somehow it gives the radio a sort of impact relief--breaks the fall somewhat. Wonderful travel radio, easy to find something to listen to with the preprogrammed search banks. Programmable search banks, as well, enable you to do some custom searching. Good radio for military air UHF, too. Free software and cable.
Difference will be night and day
There is a slight tonal difference between my BCT-15X and SDS200 but it is definitely not a "night and day" difference when it comes to performance... At the time I had mine side by side, each of them were connected to their own Icom AH-7000 discone antenna at about 40ish feet on two separate towers with each using 100' of relatively new Times Microwave LMR-400. I did this testing because I was reading how many people seemed disappointed with the analog reception on the SDS200 and wanted to see for myself if I just bought a piece of junk. And might I add that I was quite pleased with how it preformed, well minus that damn hum I had to come up with a fix for since Uniden FAILED with a piece of metal they thought they could pawn off on us rather than pulling up their big girl panties and fix the damn things the right way...
So could it have been the radio and/or antenna system it was connected to when you compared yours?
I have both models of x36HP and an SDS100 and have no issues.
redbeard, he was comparing those two radios (yours) against the Uniden BCT-15X (base) and BC125AT (portable) radios.
Ubbe
Stockholm, Sweden
Yes, they all have pretty much the same bench test sensitivity specs but what differs are when you have a demanding RF situation where it matters how well it will handle interfering neigbouring frequencies. And with SDS scanners it might not need to be an adjacent frequency as they could be affected by signals several MHz away. It all depends of your own unique RF enviroment and some people will say that they have no problems at all while others have huge issues and both insists that the other person are wrong.
/Ubbe
Did that somehow come up prior to your injection(s) into this conversation? If not, then why did you think there was a need say that?
Just askin' cuz upon re-reading this thread again, after you posted, I don't see where anybody insisted anybody else was wrong about anything... They did however print their own findings and asked questions...
I just don't get it...
Yeah, I'm lying, I do get it, quite clearly in fact... No need for you to respond... Wouldn't do much good even if you did...
900mhz
/Ubbe
You touch on an often overlooked situation..."unique RF environment". What I have learned is that no matter the scanner type, the front ends are easily subjected to reception issues due to overall channel or spectrum power. Case in point...I have a decent setup here, but was having VHF high band reception issues (very poor sensitivity) across the band. Low band, UHF, 700,800,900 Mhz had no issues. Just VHF high. I grabbed a HP spectrum analyzer to see why. It was an easy find. A local full powered TV transmitter broadcasting on Channel 10 digital was by far blowing the band out of the water. My antennas are line of sight to this transmitter. It would not cause issues with my RF limiter, but overwhelmed the scanners. So, I had to fabricate a notch filter ( I decided 8 MHz wide) and was able to notch this offending transmitter more than 120 dB from before I started with minimal insertion loss to my desired listening VHF frequencies. As a aside, my high band Motorola radios ere unaffected by this TV transmitter. Being a retired CATV headend engineer, this was easy to build. Now, I can hear stuff over 100 miles or more away easily on high band.
So, the term "unique RF environment" rings so, so true. Even f you don't think you have a problem, and you can access an analyzer, by all means do it...it cannot hurt
redbeard
BEE00.348-3.1
Maybe he's referring to how my comment was immediately deemed 'sad' and 'untrue' but hey if everyone wants to discount my experience based on 'unique rf environments' that were not part of the original conversation or even alluded to... Go ahead and add some more qualifiers after the fact to make me wrong. You can see by my signature lines that I have quite an assortment of radios and even more I've used and sold off no longer listed. There isn't one in my list that I would grab over another merely because it has 'a better receiver' than another. My point was a simple one, a cheaper model doesn't 'receive less' than a more expensive one and the differences are mostly features. If someone wants to call me a liar then put the radios in question on test equipment and prove the sensitivity or lack thereof.
