What do you think it could be? And what could it be used for?
Easiest way to explain it, would be old school telemetry Using DTMF to reportWhat do you think it could be? And what could it be used for?
Thanks I'll look more into it.Easiest way to explain it, would be old school telemetry Using DTMF to report
likely this is your target/find
is it repetitive fast DTMF Tones? ive been to disney area in the vicinity of the park and have heard this on 467.7625. im currently searching my entire database for that freq plus the one you mentioned for a recording.I'm monitoring 461.875/461.8875 at Disney world in Magic Kingdom and I'm hearing multiple dtmf bursts on this frequency in use anyone know what this could be?
It was repetitive and then it changed to another set of DTMF tones and then went silent.is it repetitive fast DTMF Tones? ive been to disney area in the vicinity of the park and have heard this on 467.7625. im currently searching my entire database for that freq plus the one you mentioned for a recording.
I'll be returning in July with a radio that records I'm hoping it'll still be active.im still looking, but as of yet i haven't found any recordings of what i remember.
what i remember it was very fast DTMF and somewhat rhythmic.
Here's the audio of the DTMF burstsim still looking, but as of yet i haven't found any recordings of what i remember.
IS that one long large DTMF sequence, or did your recorder not record the transmitter drop, never heard one continue that long in sequence.Here's the audio of the DTMF bursts
I had to crop the recording to when the DTMF started because it was mostly just a broadcast of silence.IS that one long large DTMF sequence, or did your recorder not record the transmitter drop, never heard one continue that long in sequence.
-kI had to crop the recording to when the DTMF started because it was mostly just a broadcast of silence.
It's a gold mine of data burst channels out here I found another one.-k
And unless you can sit at Hunters with your Antenna Off and capture it then, all still speculation but highly probably that this is the source
Idk if it's just a coincidence but the DTMF also seems to be going off during magic kingdoms fireworks but it's just an assumption.-k
what was the frequency you are referencing, just finding?It's a gold mine of data burst channels out here I found another one.
this is the 461.875/8875 freq you referenced earlier in the thread?Here's the audio of the DTMF bursts
Yepthis is the 461.875/8875 freq you referenced earlier in the thread?
I was monitoring some kind of data bursts on 451.657 if that is the correct frequency I'll upload the audio of it soon.what was the frequency you are referencing, just finding?
451.657 is not a valid US Freq AllocationI was monitoring some kind of data bursts on 451.657 if that is the correct frequency I'll upload the audio of it soon.
