needairtime
Whatever you choose, anything that doesn't have a connection to some sort of atomic clock will drift, including those "atomic clocks" that can't pick up the WWVB signal which is the true atomic clock. But excepting this situation the atomic clocks I've had don't drift, I'm using a Lacrosse WS9625U-IT weather station with WWVB reception, and despite being battery operated, it hasn't drifted much like most of my older AC-powered clocks. It too has a keyhole slot for wall use, but I have it set on a counter.
I've started noticing AC mains powered clocks that don't actually use line frequency as a time reference, so beware of choosing those. Most older line powered clock radios depend on line frequency and only drift when on reserve battery power. The newer ones end up using a crystal oscillator, though still fairly good, will still drift. These tend to have switch mode wall warts that don't pass the line frequency signal as a timing source. But do watch out, some power companies are trying to lobby their governments to not have to stick to fixed line frequency which would throw off these clocks' accuracy.
