After reprogramming my SDS200 I've been having problems with the SDS200 scanning properly due to GPS problems. My scanner is dash mounted with Uniden GPS puck for the SDS200, GPS data is programmed correctly, and GPS control is enabled for all favorite lists that I want it to be enabled on. The problem is after programming the scanner using Butel nothing is being unlocked or locked out when traveling using GPS location. To get it working properly I had to go into Location setting and attempt to auto locate. After doing this the scanner would work properly using the GPS setting. The scanner worked properly for about a week then yesterday all of the sudden while scanning "nothing available to scan" popped up. I had to go into location setting and attempt to auto locate again. This time the scanner stated it was unable to determine my location but the GPS function started working properly again.
I have had other issues after programming the SDS200 using Butel. Multiple times systems and favorite lists that are enabled in the software were not enable in the scanner. I don't know if this is a problem with GPS puck, scanner, or the software. I use Butel to program my SDS200s and BCD536. I have zero issues when I program the 536 using Butel. Any help attempting to figure this out would be greatly appreciated.
