GRE cable for Icom CI-V?
eorange
♦Insane Asylum Premium Member♦
Cleveland, OH
I've been reading that people use their Radio Shack #20-047 programming cable as a CI-V cable for their Icom radios. I never thought of doing that, let alone thought that's all that cable is.
So...has anyone done this with an Icom 706MKIIg? I'd like to start using it for PSK-31 with HRD / DM780. I don't have the RS cable, but I do have the GRE (30-3290) cable.
I already have the audio covered with a homebrew isolation box I used with my FT-1000D. Just need the CI-V for control and PTT functionality.
Thoughts?
3UFN
Thoughts?
Just as a side note. I use the Icom CI-V cable and made a jumper to a stereo 1/8" plug with the tip & ring fed with the data line from the CI-V. Much less expensive than the RS or GRE cables and you can use it for other rigs if need be. Just a little soldering involved.
eorange
Cleveland, OH
I just discovered that PTT triggering (non-VOX) is not possible via CAT. I don't need the control as much as I need that. Grrr...
