jnojr
I'm planning on putting up a Diamond X50 on a 10' mast attached to the gable of a 2 story house (different than my "stealth antenna" question!) I'm looking into grounding, and am hearing everything from "Bah, don't bother!" to "YOU ABSOLUTELY MUST HAVE AN ELABORATE GROUNDING SYSTEM OR YOU AND ALL YOU LOVE WILL DIE!!!1!!1"
This antenna will not be near the electric panel. There is a cold water pipe on the same wall... I figure I could run a ground wire to it. Is that going to be sufficient?
There will be a lightning arrestor in the coax, and it needs to be grounded as well, so... same place?
