shedding some light on the subject
yep I'm still around, here is the proposed setup and some more interesting info, As the system is built up, all GCSO and VFD's in Guadalupe County will switch to the Kenwood Nexedge system. a P25 repeater will be put up and patched to the nexedge system thereby giving it "interoperability" with other VHFs. There are many hurdles to jump in order for this system to become operable with one of those hurdles cleared with the acquisition of the 4.9Ghz stuff. Another is licensing the necessary freqs to support this system (more to come on that later). Effective January 31, a new paging tone scheme will be implemented along with the narrowbanding of all fire channels including the tac channels and new berlin's repeater. the tones will be changed from the old 3 second 1 second to 1 second 3 second timing and all the tones will change with the timing change as well to allow for some additional flexibility for notification purposes. (ugh, have to train my ears to a new set of tones now). At this time it looks like the two fire channels will stay analog to enable the two tone dispatches to the fire departments so you would at the very least still be able to monitor those. There is talk of Seguin having capability to patch into the fire related talkgroups to enable EMS and First Responders to communicate. Also looks like Seguin FD will be moving to P25 as well. The Kenwood nexedge equipment is easily (not affordably though) upgraded to P25 by way of software flash so that is the reference to the P25 upgrade as well as the P25 repeater for patching. I can speak for my department only at this point with reference to others that we are in the process of slowly acquiring new nexedge equipment in preparation for the new system. Another interesting thing of note is that there is talk of a total of 5 sites for the nexedge system. Don't know if that will work out but that is the talk right now. I am sure that there will be plenty of opinions as to the interoperable arguement on P25 vs any other protocol but I can say this, the current system although seems to work fine, has many dead spots, several of which are in the western part of the county and also in the southeastern parts. if the system is designed correctly with the 5 sites, it will be a major improvement to our current system and will provide near 100% portable coverage throughout the county. We will still have the capability to communicate on analog tac and TX interoperability channels and with the patch, to the VHF P25 repeater. In the future, the infrastructure and subscriber equipment can and most likely will be switched to the P25 protocol. In the meantime, the idea is to provide for an improvement over the current system in place, be in compliance with the narrowbanding mandate and set ourselves up for a future upgrade to P25. More info to come with time as I can share it.
