Ham Operator
dallascowboys
Dothan Alabama
Hi everyone I am wanting to know how much it cost to become a Ham Operator and where to go to do this, I live in Dothan Alabama, Houston County, I have see on social media that Montgomery Offers online but I do not trust to much stuff that is on social media.
Thanks for your help.
fxdscon
¯\_(ツ)_/¯
Your neighbors at this club should be able to get you started, just give them a call!
http://w4dhn.org/?page_id=8
W6SAE
Woodland, California
Regarding cost, there is no fee for the license itself; however the volunteer examiner (VE) may charge a small fee to cover costs. $15 seems to be the norm.
Also, www.arrl.org has useful information.
K7MEM
Swartz Creek, Michigan
When I took the license tests, it was $8.50. But that was a while ago (1999), so $15 sounds about right. Note that the fee is only to cover the expenses incurred (test material, pencils, etc.), by the VEs. As mentioned earlier, check with a local amateur radio club.
You should also add in the cost of studying for the tests. This isn't something you can put a dollar figure on, but it is going to cost you some time. There are various on-line study areas on eHam.net and QRZ.com. At both places, the entire question pool is available along with practice tests. If you regularly score 80-90 percent on the practice tests, your ready to take the real test. The real test uses the same question pool.
But all of that only gets a license. It's up to you to determine what you want to do with it. If all you want to do is work the VHF/UHF bands (repeaters, simplex, satellite, etc.) the initial cost of equipment can be low. If you're handy at building things, you can make your own antenna. You can also build your own transceiver, but that is a very different issue. If you intend to work SSB/CW/Digital Modes on the low bands (160 - 10 meters) the cost of equipment may get higher and the antennas get bigger. However, there is usually something available that will fit almost any budget.
Good luck on getting your license.
Martin - K7MEM
NZ4ZN
Louisa, VA
I'd agree with the posts above, especially K7MEM's explanation. Licensing cost is between free and cheap, but like getting your driver's license, the cost of the license itself is nothing compared to the equipment.
I'd encourage you to study for both Technician and General at the same time. The General uses many of the same test questions and both exams are of similar makeup. If you can pass Tech, you're probably good for at least 50% on the General exam. Keep it in perspective and study smart. Higher math has always been my Nemesis and I have always had trouble remembering convoluted formulas. I really sweated studying for my exam for Extra, but eventually realized that I was killing myself over the equations for nothing because if I aced the rest of the exam, I could afford to miss ALL of the formulas. This allowed me to relax and actually study, and eventually I could remember the formulas too.
If you join QRZ.Com as a forum member, you can use their online study program to prepare for testing. It will track your progress and help you decide exactly what subjects require further study. There are other similar systems at other sites as well.
Making your own antennas isn't too bad if you're handy with hand tools. I've built my own VHF/UHF (J-poles, ground planes & dipole) antennas for the house at very low cost. I also built my own HF antenna (fan dipole). The wire itself was only $50, but between the hardware and ropes to get it up into the trees, I probably have a couple hundred bucks into it. There is probably another $200 or so in low loss coax to feed the various antennas.
Equipment for VHF can be quite reasonable and there are many ways to get into it at low cost. I don't care for the very cheap Chinese radios. Many are simply pirated designs from legit manufacturers and most are not well made, and this alone is reason for me to reject them. Spurious emissions are often quite high, reliability quite low. An alternative is to buy a used dual band (146/440) unit for a hundred or two.
HF equipment can be pricey, but good buys can be made on used equipment here too.
There are a lot of equipment reviews over at eHam.com, among other places, so if you consider a certain model it will be easy to search for and find reviews.
Not everything needs to be done at once and you can simply get your license and ease into it. As you attend the license exam and check out local clubs, you'll often get all the help you need, including equipment loans and advice on setting up. Good luck and welcome to the hobby.
W6SAE
I came to this exact realization myself, and it made the studying and test-taking so much easier for me.
The ARRL website also has free exam reviews and practice exams on their website: Exam Practice. They worked well for me.
KE0GXN
Echo Mike Two-Seven
OP, I would search the entire State of Alabama on the ARRL site, sometimes using just city and zip code will only check just that.
For example, there are no exams offered in my city or zip code area, I had to travel to the next town north of me to find a VE team and exam location....had I not searched outside my area I would not have ever known where to go. Hopefully it does not end up being too far for you. I only ended up having to travel few miles or so to find a VE team.
As far as studying....Hamstudy.org and Roy Watson's (N1ZTL) phone app did the trick for me. I have no doubt those two study methods contributed to me scoring 100% on my Tech exam.
I also read Gordon West's Technician exam preparation book, which helped me understand the "why", but the flexibility of those two sites, especially the phone app, which is extremely convenient to use during breaks at work or when I was out and about, ultimately committed the pool questions to memory for me.
Currently using the same tools and Gordon's General exam prep book to study for my General exam I will be taking at the end of month. Don't know if I will ace that one, but I am certainly going to try. :D
Good luck to you!
