JimD88
It definately has nothing to do with the scanner location - the problem persists on my handheld outside, my base in the house, and my mobile in the car (with outside rooftop antenna).
The possible causes I could think of were:
(1) that Hamburg Fire Control's output power on UHF is below what it would normally be right now while they continue to broadcast on both UHF and low band at the same time (are they actually transmitting on low band still and only simulcasting it on UHF or actually transmitting on UHF?), and my reception problems would be resolved once they go to UHF 100% (whenever that is)
OR
(2) they are transmitting on narrow band already and that has something to do with it but I don't fully understand how that impacts receiving on something like a scanner - I use a BC350 and a Radio Shack PRO-97. Both allow programming of the full 4 decimal frequency (454.0875) but I see some newer units like the BCT15X (and also the Motorola Minitors that the fire departments use) allow modulation selection between narrow and wide band within the same frequency and perhaps that "fine tunes" the reception better in those scenarios ?
I need help from you experts
Jim
OR
Jim
