BriSch
So Hamburg runs on 460.43750 on NXDN. I have a BCD436 with the NXDN up-grade. Shouldn’t I be able to receive them?
You don't need the RAN programmed in to hear an NXDN system. It will decode in search mode with no problem.Make sure u have RAN 24 programmed as well as the freq
Will try this as so as I can today. This is probably the answer. TYIf you're using the Zip Code function on the scanner, and haven't updated the master DB, you will need to update it using Sentinel.
The scanners typically come with a really old version of the DB.
