Handheld Antenna Spanner Nut Tool / Wrench
Gilligan
Hagerstown, MD
I have a very new BCD436HP handheld and I recently purchased a UHF SMA rubber antenna that extends below the SMA tip. When I screwed the antenna down into the gap around the plug, it pushed so tightly against the nut that unscrewing the antenna also unscrewed the nut around the antenna socket. I was able to tighten it again with a small screwdriver, but I was wondering if there is some kind of tool that the repair techs use for these antenna nuts. I did a brief google search and it sounds like the tool may be called an antenna spanner nut tool or something. Thanks for any help on this.
hiegtx
Dallas, TX
I have a couple of these somewhere in my collection. Used them years ago on radio mounting knobs on old style car radios.
jaspence
Michigan
Antenna nut
I have used a pair of needle nose pliers as a wrench. My choice is a pair of Snap-On with the tips bent at a 45 degree angle (they were made that way) that works quite well. My hobby is repairing vintage HTs and I have used them not only on antennas but ear phone and power connectors with the same type of nut.
n9mxq
Belvidere IL
A drop of loctite on the nut will help prevent this from happening again.. I've also used a smaller pair of needle nose bent at 45 or 90 degrees.. They do sell special tools for this on eBay and other places, but pliers work just as well.
methusaleh
New England
I can't quite get a good mental picture of what happened, but to move those little slit-sided washer type nuts, I've used a tiny flathead screwdriver (sitting in the slit, at a sharp angle) and gently hit it with a hammer to make the nut turn in the direction I wanted it to.
Gilligan
Hagerstown, MD
Would anyone have a link to a website showing a tool that has been identified as the correct size for SMA nuts?
Gilligan
Hagerstown, MD
Thanks so much!!! Just ordered one -- it's coming from China so I won't have it for about a month but that's okay :) Thank you everyone for all your help!
