You’re welcome. Harris has its learning curve. For the 731, it might take a few revisions of your programming to get things set up as far as order of menus, backlight, volume, and stuff like that… just little tweaks and preferences, and exploring menus etc. It really is almost exactly a handheld 721, complete with integrated mic.
Oh, and make sure you have firmware installed that matches the firmware version of the brick 😉.
Some of the older install manuals have instructions for making the headphone/headset connections. It basically explains how to wire from the ‘speaker out’ of the interface box, through some 10 ohm resistors, to the headphones. There’s an ext mic in, and you can assign an aux input to PTT, then wire a switch. (You can use similar wiring to interface with a sound card modem!)
I set the other input to ‘alt PTT’, then set up the programming to alt PTT the APRS channel… so I can have APRS running on a computer, and be talking on whatever channel I want and the APRS will beacon on the proper frequency. It’s good stuff!
-B
