HARRIS XG-75PE Not Powering up
JackRimawi
My name is jack i have a harris xg-75pe its not powering up with the battery install or i when i put it in the charger and i dont if the battery is dead dead
i would love some feedback
rescue161
KE4FHH
Hubert, NC
Does the LED on top briefly flash? It could be inhibited. Have you tried to read the radio with RPM in its current state?
radiotech33
County line road
Is the charger working ? Red light Blinking slow then go to solid green for chargeing .If the red light stays Blinking fast you got a bad battery but still should boot up in the charger .Check pogo pins on the back side of the radio 3 gold pins to make sure they not damaged They spring loaded ..Push to make sure they not broken or stuck down . Last but not least dose the off/ on switch Feel ok when powering the radio up ? do you feel a click ? when turning it on. Not much else to check theres a internal fuse inside the Radio f301 But I dought thats the issue..Other than that the radio might be BRICKED..Lets hope not
JackRimawi
When the battery is in the charger it goes from red to flashing green it does not stay on red for long and when the radio it's in the charger it doesn't power to
rescue161
KE4FHH
Hubert, NC
If you have a programming cable, try to read the radio. If it reads and if it is inhibited (bricked), it will report that in RPM. Then you'll know for sure.
JackRimawi
Ok I'm trying that right now I have RPM R14C05
It couldn't initialize the radio, it's telling me to make sure it's in programming mode
If sose come down to the fuse how do I open the radio a get a replacement for it
FKimble
Newnan, GA
Go to the pics and compare your radio to the pics. Look for scratches or scuffs etc. Do they match your radio?
If a guy has a bunch of used radios to sell, he may only take pics of the best looking one! That works/powers on.
Frank
K2NEC
NA
Maby he wants to fix it his self......maby hes trying to learn..
If he buys a radio that's claimed to be working and is not working on arrival, OP has a right to request a working radio because that's what he paid for.
FKimble
Newnan, GA
Pic with a serial number is meaningless.All it tells you is the seller had it. If he sends it to you it also means he had it. Serial is on back under battery. Hard to take a pic with front showing it working and rear showing serial # without a battery.
Frank
JackRimawi
UPDATE: The original battle was from GTSPOWER and it went bad my new battery that arrived today I got it from haloidradios.com and the radio powers on and fully working
