Harris XG100P Feature String Upgrade
KC2TJS
Yes, I updated the feature string on one of my XG-100P radios to include phase 2 back in March of this year. You have to read the current feature string off the radio send it to the dealer. They send it to Harris it cost me $250. The dealer will send you the new feature string for you to upload to your radio.
BMDaug
I am licensed…
Central Colorado, USA
All XG100Ps are FPP. You just need to program a known password and set user UI privilege to full under Unity Portable/Mobile Options. Then, as long as scan is not engaged and you are in a conventional system you can hit the CH INFO button, then EDIT CHAN. Enter your password you entered in RPM, and you can edit channel parameters.
-B
KC8ONR
bridgeport
What dealer did you use? Most won't even play nice with Average Joe Citizen
KC2TJS
I used Metrotalk Inc. The salesman I worked with was Frank Sampedro. I know what you say I live near Rochester, NY. a lot of the radios are made here in town. I couldn’t get the local dealer to even respond via email. But someone on the forums referred me to Metrotalk for my Phase 2 programming I have also purchased a program cable for another Harris radio I own through Metrotalk. 73s
Scottsbluff, NE 69361
has anyone ever worked with Roberto Irizarry of mutual aid supplies on ebay? does anyone know if he is reputable? i was planning in a couple months to use him to get the feature upgrade to phase ii. he has a lot of ebay sales i believe more than 15000 and 100% feedback.
but i thought i would double check here first.
bar422
Ive dealt with him before.....no issues at all.
KJ4SKP
-B
Is there a way for me to see if this FPP feature has been enabled on my radio?
BMDaug
I am licensed…
Again, this is not a ‘feature’ that has to be added by Harris. It’s an option you need to enable through RPM. As long as scan is not engaged and you are in a conventional system you can hit the CH INFO button, then EDIT CHAN. If EDIT CHAN does not appear on the selected channel, check the RPM options for that mission plan.
-B
