Having Trouble hearing Pasco county sheriff
RMH77
Holiday FL
I am very novice at programing mt 996t with that in mind im trying to program it with the pasco county freq's but cant hear anything. Any suggestion as to what i might be doing wrong. Pinellas and hillsbrough work fine just not pasco! Thanks
mikey60
Oakland County Michigan
Pasco County is an EDACS system. (I was just visiting that area a little over a week ago, it sounded good on my PSR-500)
Be sure that you program in the frequencies in the correct LCN order and in the correct frequency slots in the system.
Mike
RMH77
Holiday FL
Mike
Thanks. I need a tutor! lol With the other two agencys i just transfer them from the ARC software to the scanner. i was assuming that everythings already in place.
mikey60
Unfortunately I'm not familiar enough with the 996t or the ARC software to be able to give you the details on how to go about it. Just remember that the frequencies have to be in the correct slots in the system configuration in order for it to work correctly.
Mike
Bolt21
Spark Chariot Driver
Punta Piñal
77, this is how Pasco looks in my ARC396 program. I don't know if ARC996 and ARC396 are the same, but maybe this will help.
Just make sure that under the "General" tab that you select "Edacs Standard/Wide" for your System Type.
RMH77
Holiday FL
Thanks, Im going to give it a try.
