Headphone issues
Sonic747
Premium Member
US
Two stereo headphones, one has 3 rings on the plug, the other has 4
crippledchicken
Butler County MO
jonwienke
More Info Coming Soon!
VA
A mono adapter shorts out half of the audio. Don't ever use one in a stereo jack.
timhir25
Willoughby, OH
If you had a stereo jack you wouldn't need the adapter because both speakers would already play, Wouldn't they? If you only had a mono jack wouldn't you use a mono to stereo adapter to get both speakers to play. Or not? When I hooked my computer speakers to my WS1098 only one speaker would play until I used the adapter and now both speakers play.
Tim
jonwienke
VA
Tim
All Uniden scanners have a stereo headphone jack.
Sonic747
Premium Member
US
OK. So I have to get a [mono to stereo] adapter or [stereo to mono] ?
crippledchicken
Butler County MO
Let me see if I've got this right, the scanner puts out a mono signal but, the jack is setup to feed both channels of a stereo plug for sound in both ears?
jonwienke
VA
That is correct. The scanner uses a stereo jack, but feeds the same audio signal to L and R. That lets you use the most common type of headphones and earbuds without an adapter, even though the scanner isn't stereo.
