Jack_Ofalltrades
- Joined
- Dec 13, 2023
- Messages
- 6
Hi gents and gals!
I was looking for some place to find radio knowledgeable persons to try to find some answers to a problem i have to deal with. We are using small frs radio as a mean to communicate in our expedition department. Our yard is not big, around 200 meter. The radio were working perfectly for a while. But we bought a new printer this summer and since then we hardly can communicate over more then 50 meter before the signal is so bad that nothing can be heard. I bought a GC EMF-390 to scan the room for possible interference i spotted some sources like the neon ballast and a battery charger. I unplugged all the possible culprit and the signal was as bad. When i scanned the printer with the meter hardly nothing at all coming from it. I tried to unplug the printer and after that i was back to be able to communicate with the radio normally.
So if no interference is coming from the printer up to the 10ghz that the meter can detect, and the printer is the problem, what could it be? There is large plate at the back of the printer, i was thinking may the plate absorb the signal? After i theorized that i measure the plate to see if it was possible for it to be the size to act as a big antenna tuned for the frs band but nope nothing close to it if it's even possible.
So i'm kinda stuck... I would greatly appreciate if someone could point me to possibilities that i could look for. I was expecting to find the source quickly and correct the situation but i now have more questions then answers... As often what look like the simplest of problem can be the most painfull to resolve...
Thank you and have a good day!
