alireza_asol
- Joined
- Feb 2, 2023
- Messages
- 1
- Reaction score
- 0
hi
i want to build an antenna for 3570 mhz frequency. using this guide:
Quados antenna online calculator - 3G-aerial
http://www.qsl.net/yu1aw/ANT_VHF/quados.pdf
is "quados 8" a good choice?
can i use thicker wire?
why there is no connection to the reflector?
also i don't know where solder the wires exactly! 😂
two sides of the antenna or the two ends of the antenna?
it has a 4:1 balun so 3 center conductors must be soldered to antenna
should i solder two ends of the antenna together? or they must be seperated?
please draw it for me if you can.
thanks a lot
thanks a lot
