Help! antenna install
Ebenge
Mt. Pleasant, IA
I have a 2006 Chevy Silverado and I am trying to figure out a good place to run the antenna wire from the bed into the cab. Any ideas?
KD0LWU
Kansas
My F-150 has vent holes at the back of the cab to let fresh air in as needed, then had plastic caps in the front of the bed that I could drill through. Not sure if Chevy has something like that or not, but I'd bet it does have the cab vents.
davidgcet
usually either on the back wall or on the floor right at the wall is a rubber grommet, just run the line thru that. bed grounding is not always great since the bed itself is mounted on rubber/plastic standoffs, so you may want to run a ground strap to the bed itself if you have strange issues such as an untunable antenna or RF bleeding into everything.
Ebenge
Mt. Pleasant, IA
I having trouble finding the rubber grommets in the back, anyone have any ideas of a location.
davidgcet
the floor humps up and usually they are on top of that. you may have to pull the carpet back a few inches to find them. is this an extended/crew cab or a regular cab?
