Help needed!
Kafx_radio
hello. I want to buy this pro 92 but I don't know if this piece is for rechargeable batteries or if it needs another one
CycleSycho
Central South Carolina
I would like to see a picture of the yellow
:) kafx, the yellow battery holder is the same size/shape of the black holder. It is recommended by members more often than not, that the batteries be charged outside the radio due to damage to both the radio and holder, and to mention anything surrounding the radio, if left unattended. Too many of these chargers overheat the batteries because the radio uses a timer to charge, not a supervised current monitor (internally). Most members recommend using an external charger designed for a supervised regulated charger so as to protect both the radio and batteries. One meltdown is all it takes ($$$ depending on how long it is before found). Good luck. :)
tvengr
Well Known Member
Baltimore County, MD
The yellow battery case looks exactly like the black case except it has an extra contact for changing rechargeable batteries. The black case is for alkaline batteries and lacks the charging contact. Alkalines have a nasty habit of leaking or exploding if you try to recharge them.
wtp
Port Charlotte FL
wtp
Port Charlotte FL
and they are two different things.
the yellow would not be able to charge the batteries somehow.
i can't remember how.
