What you are showing are talkgroups on a trunked system. They are not frequencies. The frequencies for trunked systems go into sites. Without knowing where you are (city/county/state), there is no way we can help.I have a BCD996p2 and i am using ProScan to program it and i am wondering if i am able to listen to these frequencies if so how do i go about programming them in thanks
Can a person listen to the talk groups stillWhat you are showing are talkgroups on a trunked system. They are not frequencies. The frequencies for trunked systems go into sites. Without knowing where you are (city/county/state), there is no way we can help.
Yes, if the talkgroups are not encrypted, you have the proper sites programmed, and your scanner is capable of receiving the system. That is why we need to know your location and the system you want to monitor to check the database. There is no one answer. Every system is different.Can a person listen to the talk groups still
I live in Caribou Maine 04736 I have A BCD996P2 and I am using proscan to program itYes, if the talkgroups are not encrypted, you have the proper sites programmed, and your scanner is capable of receiving the system. That is why we need to know your location and the system you want to monitor to check the database. There is no one answer. Every system is different.
A quick look at the database shows that Aroostook County has a lot of conventional VHF in use. To be on the safe side I’d still program the P25 allocations in. Here’s your county & Maine’s trunked radio system page.I live in Caribou Maine 04736 I have A BCD996P2 and I am using proscan to program it
51 (33) | 051 (33) | New Sweden | Aroostook | 151.2125c | 159.270c |
Yes. Where are you at in the process? Do you already have a trunking system setup in ProScan and you want to add group/s containing the TGIDs? I see post #1 shows the TGIDs already setup.so I believe I have asked this question before but lost the information i have a BCD996P2 and I'm using ProScan to program it I believe I was told that there is a way to program talk groups into it and I'm trying to figure out how to do so thanks
If your scanner is fairly new, you will want to check your firmware version. It was discovered that a hardware change resulted in the scanner not being able to decode digital frequencies from 171.225 to 173.9875 MHz. MSCommNet uses a lot of frequencies in that range. Firmware v1.10.02 was issued 7/13/2022 to fix that problem. On your scanner: Press MENU > Scroll to Settings > Press E > Scroll to See Scanner Info > Press E > Scroll to Firmware Version > Press E > ---- > Press SCAN/SEARCH twice to exit menu.I live in Caribou Maine 04736 I have a BCD996P2 and I am using proscan to program it.
