Help programming EBRCS
spacerat
Lincoln, CA
I have a very newbie question. I am getting a new scanner the GRE PSR-500, and I need some help programming it for EBRCS. I want to listen to Livermore PD so do I add just site 007 or do I add all of the seven sites?
kma371
If you only want to listen to Livermore, yes. Add ALCO East Simulcast only.
spacerat
Lincoln, CA
LPD & PPD Choppy Audio
Thank you for the info.
I have the GRE PSR-500 Scanner programmed and scanning ALCO East Simulcast but the audio is all choppy most of the time on LPD & PPD. Any suggestions?
kma371
Well this is all kind of off topic from the thread but best way would be improve your antenna
officer_415
SF Bay Area
WayneH
Forums Veteran
Super Moderator
Your master site
Before you reply to a thread please read the previous posts. We're not allowing anyone to "hijack" the EBRCS Updates thread. It is strictly for what the subject states.
I've moved your posts to your own thread.
Boomguy
spacerat - I'm with you. I can't hear squat on my PSR-800. I've tried everything I know (translation - I'm doing something wrong). So if ANYONE can provide some instructions, that would be greatly appreciated.
I have downloaded the database from GRE, dug down to Livermore - have everything in the Livermore database loaded, I also have everything from the EBRCS loaded. I've been "locking out" no related agencies as they communicate. Over the past week, I've heard maybe 5-minutes of LPD.
Sure would be nice to listen again. All I want is LPD, LPFD, ALCO Fire and The Sheriffs Office.
kma371
Are you listening to Livermore on the 800 system or the ebrcs system?
Boomguy
Hi - I started off with the DB from GRE - I had me drill through the menu and I found LivermorePD1. I put that in my scan list - Nothing.
I then added the old frequencies as well (old 800 system).
I then came here and added all the frequencies in the DB selecting "digital" in the GRE software - Again Nothing.
I then added everything in the EBRCS and heard way too much (but no LPD - at least not much - really like maybe a total of 5 minutes all weekend) I locked out the other agencies while scanning since I know it takes the scanner sometime to sort through all the channels. Still, every once in awhile, I get some garbled transmission on the LPD channel. YES, I'm using an 800 mHz antenna.
I've been scanning since the 70's and I've never had such a hard time.
Suggestions?
kma371
You might not have chosen the right site from ebrcs for Livermore. I would only program the ALCO East Simulcast site as I hear them just fine.
Try that and let us know outcome.
Boomguy
Ok, I must be doing something wrong or LPD is not doing much talking. Receiving stuff on PD, PD2 and PD3 - but maybe a total of 5 half transmissions per couple of hours. Seems like in the old days (prior to the P25 switch) that LPD transmissions were almost endless. I actually saw on officer talking on the radio and heard nothing. I don't think all their channels are in the DB maybe?? Scanning too many channels and missing talk?? I do have the 3-channels listed as LPD set on priority. As my kids would say IDK . . . I'll give it a few more days-then back to the place that sold it to me.
kma371
Ok did you do what I said? Did you program the ALCO East Simulcast site? You may have programmed the ALCO East standalone site instead which isn't used often.
Im pretty sure its not a radio issue, it's a programming issue.
Boomguy
Of course. I follow directions well. :) I'm loading whatever GRE PSR-800 EZ Digital Handheld Trunking Software finds and only checking (downloading) ALCO East Simulcast. Using frequency DB 153 which was updated 1 Sept. As I type, the scanner is picking up more (still not like a few weeks ago) and the transmissions are getting clearer - almost like it's learning??
I'll keep everyone posted - thanks for the help!
Boomguy
I'm using one I bought a bunch of years ago and used with my old RadioShack scanner - worked great on the old 800 mHz system. I'll try a new one - suggestions for one with a BNC connector? (And yes - I know. I really need an external antenna). BTW - when I scan LLNL, it's never ending clear conversations.
bayhair
Tracy California
I too am also having problems monitoring livermore and pleasanton pd. I pick them up for short coversations then nothing for hours. I have the hp-1 and have loaded directly from the data base. It almost seems like there is a control channel missing. Any suggestions.
Thanks Harry
kma371
Thanks Harry
What site are you monitoring ?
kma371
Simulcast is what you want actually but are you sure that's what loaded? What control freqs are being monitored?
bayhair
Tracy California
Sorry for the delay work called. I have tried using control channels
773.66875
774.14375
774.89375
I have also tried
855.21250
855.46250
855.48750
Thanks Harry
