guttapercha
- Joined
- Feb 13, 2008
- Messages
- 158
Hello,
I will be visiting the area in a couple of weeks and I would like to bring my pro-96 along. From what I understand, successfully programming an EDACS system requires a precise channel order used in the scanner's bank. Can someone kindly pass along the way their radio shack scanner is programmed to cover the Lancaster/Lincoln EDACs system?
Thank you,
JD
P.S. I may be moving to the area next year for a position with UNL. If you have wonderful or not so wonderful things to say about your city - I'm all ears. I currently live in Columbus and work for OSU. I will have no problem rooting for the Huskers, by the way.
Thank you,
JD
