Antenna is inside the attic and coax goes through a lightning arrester about 4 feet from the antenna base. The arrester is grounded to electrical conduit in the attic. Is this enough or do I need to ground the coax with a grounding kit?
If you wanted to do things to code, grounding to conduit is not acceptable. The arrestor needs to be bonded to the ground rod for the structure, and if that isn't directly under the antenna, you'd need to add a ground rod AND bond that to the existing one.
That's if you want to do it to code.
Grounding to the conduit ~should~ be sufficient for just grounding things, but it's not to code and probably isn't causing your issues.
Unless you are going to add the ground rods/bonding, I'd not spend a whole lot of time focusing on that. I bet you'd find that 95% of hobbyists don't ground anything and somehow survive.
I'll check the connections again but this is a brand new install. I guess I didn't do my homework on the LMR-240 for a 90 foot run. I thought it would be ok. I suppose I should at least be able to pick up something and not attribute the inability to pick up any signals due to loss?
Make 100% sure your outdoor connections are fully waterproofed. If you did not do that, its possible water got in and corroded something.
As for being able to pick up something, I don't know about that.
The discone antenna isn't doing you any favors with zero gain.
The long/lossy coax isn't doing you any favors by losing that much signal.
Having the antenna low and behind the building isn't doing you any favors.
Without knowing exactly where you are in relation to the systems you want to listen to, no one would be able to confirm or deny that you should be able to hear something.
But, hearing zero, that's usually a sign that something isn't connected somewhere, something failed, or the coax was cut/damaged. No way we can determine that from the photo or the evidence you have provided.
Also, how does one sniff around with the antenna off the scanner? I'm not familiar with the terminology but I'm guessing put the scanner on close call and watch the bands if any light up?
I appreciate the help!
Remove the antenna, walk around and see if the signal level peaks around electronics.
But, I don't think that is your problem, and having your antenna outside is going to be one of the best things you can do to eliminate that.
I really think you need to start at one end of your antenna system. Inspect every single inch of coaxial cable, each connector, each device, everything very carefully, and you'll likely find some issue(s).
