CDM Help with CDM-1550LS+ (6AN model) Message and Status Decoding
Tfinnm
Alright, so I have a setup of some HT-series portables, which notably includes an HT1250s that I recently programmed to be able to transmit MDC statuses and MDC messages. I have a CDM-1550 LS+ (the 6AN model) as a base station that I operate on only conventional channels. Now, on both the HT1250 and the CDM1550, I have all of the statuses and messages identical in both code plugs, and on the main operations channel they are both using an identical MDC system (except that primary IDs are changed) for both Tx and Rx. Both MDC id display and emergency decode work between these radios on this channel. Here's the issue: when I try to transmit a status or message with the HT1250, I hear the MDC come through the CDM1550, but it doesn't do anything and after a few seconds the HT1250 just shows "NO ACKNOWLEDGE". Using my SDR and an MDC decoder, I've verified that the HT1250 is transmitting valid MDC messages, and in CPS for the CDM, I've checked the decode box in the message section of the MDC system. So, any ideas what I might be doing wrong?
Tfinnm
The user manual for the radio explicitly states that it can decode and acknowledge them, it even has diagrams showing what the radio should do and show when it does, it's just a matter of programming.
jeepsandradios
East of the Mississippi
I just read thru the manual - chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.repeater-builder.com/motorola/cdm/pdfs/cdm1550ls+-220mhz-mobile-radio-user-manual-6864110r13-o.pdf
I dont see where it says it decodes status messages. It says it can send to base. Standard messages should decode like the HT1250.
