ProScan: Help with Nxdn
Sonoma County, CA
Hello, I accidently deleted all my back up files, I forgot how to correctly add nxdn to my uniden sds 100 using proscan.
Someone has a simple list on this forum on how to do it very easily but I cant find it.
Thanks.
ProScan
Software Provider
Ontario, Calif.
Thanks.
If you already have the system programmed in the scanner then in ProScan, create a new Favorites list then read from the scanner.
If you don't have it in the scanner then you can import from the RRDB or from Sentinel. If making a system from scratch then choose NXDN Trunk for the system type.
  • Like
Reactions: Dog
Sonoma County, CA
Hello, I just want to be sure Im not missing any steps in this process,
SDS100 with Nxdn upgrade, and using ProScan and RadioReference to make
my favorite list. If one of those favorites is using Nxdn, do I just normally
transferred to the scanner like the rest of the favorites or is there any other
steps for the purpose of listening to Nxdn.
ProScan
Software Provider
Ontario, Calif.
No additional steps with regards to NXDN. When the system was imported from the RRDB, the trunking frequencies LCNs and RAN #'s are also imported.
