I do remember Gene Proctor and Laslo. Not much else in people. My cage was right off the assembly stations and those laid out for a couple products.
About all I recall is the 1000m was assembled in the same building. What boards or sub assemblies were imported, I dont know.
These had the PLL board, the Kokusai SSB filters, I think were the best. A push pull class B AM modulator. A mitsubishi 2SC2312 final, good for about 18 watts PEP
The boards were not completely stuffed, I had to choose the bias resistors for the AM modulator and install those.
I had to choose the driver bias resistor so the last two gain stages were class AB-1 (linear)
Then had to balance the SSB modulator and adjust the gain and APC. Specs called for < 24 watt input.
RF output peaking and the radio went back to assembly for the case and cosmetics.
I worked there to 11 months when the CEO called employees to that large lunch room, given a letter of recommendation, severance bonus, and a handshake. I asked about migrating to the marine radio division but no luck. the only bad day there I will remember.
I do know shortly after that, the marine radio division was sold to Regency. later closed everything.
Oh yea, I was 6'2", good eyesight and fair hearing then.
