Help with Programming a NX5700-K
will_545
Kpg46xm would be an oem cable, the 46U is the old USB cable.
This sounds like a driver issue to me.
The other way is to take a db9 to db25 adapter or cable, and a USB to db9, plug it into the rear db25 and try to read it that way. I have done this with the older radios nx800 and 8180's when the mic jack is not working.
I would for you sanity, get the 46XM cable for faster reading/writing.
I have a question. I have a NX-5700 that I can't read threw the mic port. I can read other radios that I have so I am thinking it's something with the mic. What kind of cable are you using to read it threw the db25 port i am wanting to try it that way.
Cognomen
Radioactive Zone
I've seen a few NX-5000 mobiles where something in the display board failed, causing this issue. A new display board fixed it, or you can temporarily swap the head with another NX-5000 for programming.
will_545
I will try that thanks.
70cutlass442
Not to resurrect an older thread... but I too am having issues. I am using the KPG-46z Cable. I can go into test mode and toggle channels, key radio, etc. But when I read the radio I am met with a com error and the radio beeps and resets. Anyone seen this before?
70cutlass442
Hold the key with the overlapping squares and turn the radio on. That will put you into Radio Info mode.
I think may be the issue. It looks like 4.24 came out in April of 2020, 4.20 is from December 19. Now I get to figure out how to upgrade to the newer s/w
There was a funky software/firmware change made around 4.1 - 4.20, but I think you are above that. But it wouldn't hurt to update firmware to a newer version.
Maybe @kd4efm can refresh my memory about the firmware/software thing.
70cutlass442
From the TSB I am reading, software version 4.20 is for F/W 4.20 and older.
KPG-D1N V4.20 - KENWOOD myTools (kenwoodusa.com)
Hopefully he can point me to the exact s/w version I will need. Thanks for your help!
70cutlass442
if it does not have kwd-5100cv on it, you did not get the licenses. Radio is p25 ready
Just ordered 4 P25 licenses. Talk about an unanticipated expense. These radios were bought without any input from the agency that dispatches for them so there have been a few surprises with these.
Ofdpt23
are there good reliable places to order a Kpg46xm ??? My local kenwood radio dealer is not a reliable source for purchasing anything (my company is still waiting on parts for a project they started 3 years ago).
