Help with Unication info
K9KLC
Southwest, IL
I repeat, the pager is not a scanner and it scans slow. I if you have 16 frequencies in a scan list it will be slow.
I found this out after I tried to put in some stuff for a local PD that uses both analog and DMR together. I finally decided to use "something else" when possible for scanning those.
bobruzzo
W1AV
Cranston, Rhode Island
Yeah I am beginning to think that way....I thought maybe I could populate empty spaces with more freqs.......no big deal cause theres enough on RISCON to listen to anyway. I have 2 DMR ham radio HT's I use for both Ham and monitoring everything else. But it is great to have a handheld unit like the G5 to be able to listen to RISCON, especially when I am on the road around town.
bobruzzo
W1AV
I think you have to pull off RR to enter into the G5. You have to keep analog and P25 conventional separate.
OK so you cant MANUALLY enter the data like ctcss/dcs and color codes/time slots. I know Pawtucket PD is on P25 now and Johnston Fire too. Stand alone like Cranston is. I guess in the least I could program those towns that are P25 conventional.
jtwalker
Gettysburg, PA & Fenwick Island, DE
I still dont get how there are more than 1 sites in a zone....how would you get to those other zones, 2, 3, 4 etc from one knob position?
See post #3. You don’t get to them, the pager picks one site and stays there until signal deteriorates and then it tries to find a signal from another site.
bobruzzo
W1AV
OH OK.......I spend pretty much all of my time here in town so I really wouldnt need that feature. I wouldnt be venturing outta range of what I have programmed now.
Bob, you need to make another change to your E7 knob positions, my fault, I always get confused. The settings you have now monitors all TGs, programmed or not, this change only monitors the TGs you programmed.
Click on the gear icon circled next to TG Monitor
and change it to TG - Scan, save at page bottom and reprogram
bobruzzo
W1AV
OK Thank you....but I get this error. I tried to add one talk group from my non priority list but it wont let me edit.
bobruzzo
W1AV
If I click on the SUB GROUP button at bottom of non priority list I get this first screen.....if I click on one of the TG's to assign to sub group I get the next screen but I am lost here and dont know what to do next. Looks like there are no sub groups....look in last pic. I also noticed radio isnt showing "scanning" in the display. But it is receiving talk groups.
bobruzzo
W1AV
Look, there is a LOGO on the display now! I did change what you said.....but I am not sure if the word "scanning" is supposed to go across screen.....
bobruzzo
W1AV
I got rid of logo.....and I thought I did see "scanning" but I think that is scanning for control channel....seems to be working very well...very active receives very nice...good audio.....I also added the "Hold" feature.
jtwalker
On a trunked system, scanning only shows until pager locks on a control channel. Then it will show rfss/site.
On conventional channels, scanning will continue to show until squelch breaks. Then show again after squelch closes.
bobruzzo
W1AV
Yes, I am starting to learn a bit more......I will take my time with this and maybe get some help on programming the last 2 empty knob positions on radio. I see where I will have to import from Radio Reference what I want. But I still am not clear how to get the data where it needs to go. I think I will import some conventional UHF PD/FD from surrounding towns. I also have the DMR option but maybe I really didnt need it cause it seems programming stand alone DMR freqs, not a system might not work.
peteymcsweety
cincinnati. Ohio
I am thinking about buying a Unication, from what I have read I am sold. Do they make a version that will run more than 1 site? I understand these radios will only scan 1 site at a time, but can you program say maybe 2 or 3 sites where you can pick any of those to scan? I live on the border of 2 site areas and would like to be able to listen mainly to the Providence RI site, and I am only a few miles south of there. But I live in the NORTH site area and would still want to hear calls from that area as well.
You can scan up to 64 sites on a zone
bobruzzo
W1AV
You mean 64 TALK GROUPS. I have 6 sites programmed for local state P25 system. For the heck of it Programmed some DMR business freqs and some Analog stuff......receives the P25 all over the place very well. The DMR and analog not bad within my town......
