Help
Boblmsc
VA
Anyone from Richmond VA using a BCD436hp? I can't receive police calls for Richmond, Henrico, Chesterfield or Colonial Heights only Fire dispatch. Help
K4EET
Chaplain
Severn, Maryland, USA
IIRC, they went full encryption about a year ago. Perhaps somebody from Virginia can confirm that.
BTW, welcome to Radio Reference!
There is still a lot of other things to listen to on the airwaves. Check out the Radio Reference database for Richmond, VA.
K4EET
Chaplain
@Boblmsc, take a look at this page:
Look at the "Mode" column. Where you see a capital "E" that means full-time encryption. A lower case "e" means part-time encryption.
By encryption, we are saying that no scanner can decode what is being transmitted.
K4EET
Chaplain
They went encrypted further back than I thought. It was July 2, 2018. See:
tvengr
Well Known Member
Baltimore County, MD
Fire is open to receive for Richmond, Henrico, and Chesterfield except for one talkgroup on the Richmond system. There is no reason you are receiving dispatch only unless the other talkgroups are not programmed. You should have service types Fire Dispatch, Fire Tac, Fire Talk, EMS Dispatch, EMS Tac, and EMS Talk enabled in the profile to receive all of the Fire and EMS talkgroups.. Only the Dispatch service types are enabled by default. If you programmed the talkgroups manually without the Tag, Custom 1 service type should be enabled also.
fredva
Virginia/West Virginia
Well, how far are we extending the I-64 reference? I-64 goes east and west of Richmond, and there are counties to the west of the Richmond area that are not currently encrypted.
kc4jgc
Virginia Beach, VA
Norfolk, Chesapeake, Virginia Beach PD's are not encrypted. I don't know how long VB will remain that way however. In the other direction, Charlottesville/Albemarle County is not encrypted yet. Neither is Augusta County.
