Henderson,Ky Site Freq change SAFE-T
trido
Southern In
We have Henderson,Ky site freq have changed today.
New ones are
868.5500 * data
867.0375
866.7625
866.6375
866.2250
Not sure why they may have originaly had some issues with Ky and now they are coordinated again.
These may have been the original issued freq RR had posted.
trido
Southern In
scanner_freak said:
Yep, they are. Thanks :) I made the change!
can you tell from original listing what is the back up data channel?
thanks
scannerfreak
Well Known Member
Indiana
I have it as 866.7625, but that may have changed. Maybe Chris or someone else close can run trunker on it.
KD4YGG
It will be a while before I'm down that way. Will put it on my "to do list".
kd4bas
Monitoring, Hanging Out, & --mn-@v@-mn-- you.
Morganfield, (Union Co) KY
The records I have (date 5/12/06) shows 866.76250 as the back up. Would the back up be broadcasting a data signal along with the primary frequency?
scannerfreak
Well Known Member
Indiana
No, It's only there as a back-up. AFAIK, none of the sites alternate control channels on a regular basis. Since we both have that frequency, I'm going to go with it in the db. Thanks:)
