Hiking a Di-pole up a mountain?
I'm gonna try to find someone in the area with a decent base CB rig to catch me tx'ing off a local mountain here in TN.
This mountain will be facing the northwest, and is 2,100 feet above the ground below.
I'm curious what kind of distance I could estimate on getting. I just bought an 11 meter dipole antenna to take up there and throw up on some trees.
Either way, I'd like to write up the experience.
LtDoc
Oklahoma
I think you'll see the same 'range' as you would with any 1/2 wave antenna with the same polarization. That last part, the polarization, can make a large difference if yours and the other station's isn't the same.
- 'Doc
- 'Doc
maybe I can bring a couple different antennas up there. I also have a 4' firestikII.
