Since having the Home Patrol for a day I have a better understanding on how the RR Database is/should be setup. In a way I was already doing this with my Uniden Dynamic Memory Scanners. With the HP-1 it is setup to display the following. I will use Escambia County Florida as an example.
What HP-1 Displays:
-Line 1 “System”
-Line 2 “Department”
-Line 3 “Channel”
What I see on the HP-1.
-Escambia
-Escambia, County of
-Sheriff South
As you can see lines 1 is missing COUNTY after Escambia and line 3 look fine but could be more defined. Line 2, department is also displaying the county and not the actual department. It should be referring to the department I’m monitoring, Escambia County Sheriff. From reading the database admin handbook, this is due to how they have counties setup. You don’t see this problem with most trunk systems since there already broken down by Police TG, Fire TG, etc.
If the database was setup correctly then I should be seeing this.
-Escambia County
-Escambia County Sheriff
-Ch.2 South Dispatch
With all my dynamic memory scanners, I have always broken my groups up by departments. This way I can hold or lockout a department and not the entire county. Even when I download from RR, I still have to spend a lot of time editing before it is configured correctly. Again I’m just point out my observations. I have learned a lot about the database and will use this info when submitting new updates.
What HP-1 Displays:
-Line 1 “System”
-Line 3 “Channel”
-Escambia
-Sheriff South
-Escambia County
