home patrol power saver
mitbr
Tampa Bay Florida
What exactly does this feature do and how does it work?It can be enabled via display options.Thanks in advance.
kg4jjs
Tim
Anon6083
Oddly, I cannot find a manual for the Home Patrol. If it is anything like the Battery Save feature of the handheld units (BC346XT, BCD396XT), this is an option that will turn off the radio inside of the scanner for 300ms and then re-energize it for 1sec when the scanner is held on a particular frequency.
QwKiE
Warren, Michigan
what it will do
If you turn it off. The screen will go dark after like 10 seconds if no freq keys up, but it will get bright when a freq locks on again, then go dark as no one keys up again and so on. Its a battrey saver if your on batt power. And a light saver I think, as you all know some scanners light gos out sometimes. So can save both I guess.
rdale
Lansing, MI
The manual doesn't cover power save. It's in the table of contents, but it's not actually in the manual.
UPMan
In Memoriam
Arlington, TX
I answered his original post to the Yahoo! group. If you press HELP on any screen, all options are described.
<POWER SAVE> - when turned on, HomePatrol goes into a low-power mode when it is holding on a single conventional channel.
