CalebATC
I might be missing something here and please fill me in on what your making. If your building an exposed dipole array here are some basic starting numbers.
A 4-bay array set for an omni directional pattern will theoretically have at the most 6dBD gain when the dipoles are at the right spacing to combine in phase and the power splitter or phasing harness has no loss. Lining the dipoles up on the same side will make the antenna directional and add about 3dB more gain. Adding two more elements to make it a 6-bay would give a theoretical 7.78dBD gain if everything was perfect.
Every time you double the amount of elements you can get 3dB more gain. All dipoles would have to be made for the same frequency to reach these numbers and if you make the dipoles different sizes for different frequency ranges you will give up gain where the dipoles can't all overlap in frequency.
Then there is the power divider or phasing harness. A phasing harness made from 75ohm cable is common to use for matching and power dividing dipoles in multiples of two but the bandwidth will not be that great, maybe 10% at best. A coax phasing harness for 6 dipoles would need an odd impedance coax like 91 ohm or ??
You can use a 50 ohm power divider and equal lengths of 50ohm cable to each dipole and get some wider BW (assuming the dipoles are fat w/wide BW) but if you go too wide the spacing between dipoles is not ideal and your pattern suffers and you give up gain.
So, to achieve 15dBD omni gain you would need 32 dipoles spaced and fed correctly and it would be impressively tall. It would also have a very narrow main lobe on the order of 2 degrees or so. 16 elements all on one side of the mast would give roughly the same gain in a directional pattern.
Have you seen my fairly simple 4-bay VHF dipole array project on RR? It might give you some mechanical ideas to use on your project.
prcguy
It will be made from a combination on 1/2 wave parts, 1/4/1 wave coils. The guy who made it told me it should have around 15dbd of gain when done. Depending how much you repeat the cycle, the more gain (I'm sure you know that)
It is a J pole pretty much, has a 300 ohm matching section. That will be for 301 MHz. The elements and coils will start from 250 and goto 375 Mhz, so each will have to cover that. It will be for 50ohm coax, or whatever you decide to do with the matching section.
