Still running Beta 2.06.08 and I am in fact seeing issues still with this version.
I will do the best I can to describe what is happening.
Turn the HP1 on and often it works fine, other times turn it on and it works fine or at least appears to for fine for about the firtt 15-20 minutes, then the scanner goes silent, or at least for digital trunking systems. I do not have a much analog configured in my Favorites, but I do have a VHF Low fire dispatch simulcast which is configured into my Favorites.
What I am seeing is the HP-1 will stop and do 2 different things. Often it stops on a TG however, the display will not brighten up. Having the P25 data displayed and it never shows P25, it usually is toggling with DAT and NON. Scanner appears to be stopped on a TG for a typical conversation length, then it will usually resume.
The other behavior is the scanner will stop on a TG, the display will come up to full brightness, however, again there will be no P25 decoding. The displayed info just toggles between DAT and NON, never will the decoder actually lock on any voice traffic.
Power cycling the radio does not appear to change things immediately. Sometimes power cycling sorts things, sometimes it does not. Maybe I need to leave the scanner off a bit longer when I power cycle?
Interesting I had to stop for a job and decided to leave the scanner running to see what may happen as it had gone silent on the digital Motorla systems. I left the scanner in the Debug mode and also turned on Recording just to see if in Recording mode it would catch the scanner stopping on a TG without decoding P25 traffic. I came out to the truck about 1 1/2 hour later and the scanner had crashed and must have restarted. I had the DC power feeding the scanner and the Recharge screen was up and waiting for input. I pushed Recharge then noticed that the Debugging and Recording was not longer active, but the scanner started to decode again. I see the P25 info up and debugging again.
I was very close to one of the System transmit sites where I had stopped for the job. I then stopped to pick up lunch and realized while I was watching the P25 Error rate for a System that I was a few blocks from a transmit site and while standing still I had 0% Error rate. Once I started moving, I was no higher than 10% error rate as I was right near one of the tower sites for System I was monitoring. So I do not see this as a Simulcast or signal quality issue.
I need to go back and see if I have the Debugging logs and I also tried to Video the scanner display when it basically goes stupid and does not decode P25 traffic. I am monitoring a number of Motorola digital trunked systems and I do have a few Analog channels. I did have a situation where the Analog traffic was picked up while the Motorola digital systems were not decoding.
So what I think is going on is there is something causing the P25 decoding to stall and not work. Not sure if it is firmware issue with buffers or clocking, some form of receiver drift or what is up. Analog appears to come through fine. I need to reconfigure with some Analog Trunked 800 MHz systems and see if I can at least plug in some 400 or 800 Analog channels if I can find any in my area.
Either the firmware is having issues with slight receiver drift, there is buffer filling up, some form of clocking issue. I do not think this is a radio specific issue, but not sure if something in some of the the radios is making the P25 decoding difficult.
I will hopefully be able to post back DropBox links for the Debugging and video I captured.
Might not get this info posted up until late this weekend.
These are not encrypted TG's, it app
