How can the "Durham Region Works (Alarms)" Data signal be decoded?
robibaw263
I see a lot of transmission around ~160 Mhz. Checking their Designation of Emission shows this info:
Their modulation type is `LMR-ANALOG`.
From gqrx I can see they are using NFM.
I have tried a regular NFM demodulation but there is no voice, it's definitely data.
I have also tried piping the audio to multimon-ng and dsd but they didn't help.
Is there a way to decode these on Linux?
ronenp
How do you check the emission designation ? does your radio decode it or you interprate it yourself from looking at the signal ?
do you hear data ? can you record part of the signal and spectral view of it ? it might help to identify and see what data system it is
krokus
Southeastern Michigan
16 kHz is not NFM, so try FM, then compare the noise to one of the online samples, to ID which digital mode is being used.
robibaw263
Details of such signal can be seen here:
168.96000 Multiple RM 123.0 PL D Rgn Works Durham Region Works (Alarms) FM Data
and here:
The waterfall looks like this:
I can't figure out what this signal is? Seems like it includes FFSK.
