Pro-668: how do u add cb freqs to a pro 668
but how to add them to scanner
They are in the search menu already. Scroll down to search, select service search, scroll down to CB.
To import from programming software Go to library tab and select Preferred, choose nationwide, select next, Choose CB, Click on CB at the top, click box next to CB at bottom, click next, select channels you want to import and select Import Selected Channels, select scasnlist and then import.
rivardj
Michigan
Manual Programming
You can program by browsing the library.
To program you scanner by browsing:
1. Press MENU to access the main menu.
2. Select Browse Library, then press .
3. Use the four-direction pad and SEL button to select
agencies to program. ( = selected)
4. Press MENU.
5. Select Import Selected and press SEL. A list
of playlists appears.
6. Use the four-direction pad and SEL button to select
a playlist. ( = selected)
7. Press  to import the items.
Library Structure
Each State contains three data types:
• Agencies – Statewide non-trunked systems.
• Counties/Cities – County or independent city.
• Systems – Trunked systems, including control
frequencies (sites) and talkgroups.
Note: Not all states have a statewide trunked radio
system.
thanks i see that but just search cb cant add it
I don't understand, you can use search and they will scan only CB, or you can use the simple programming steps listed in post #6 above in the programming software to put them in a scanlist.
  • Like
Reactions: wtp
wtp
Port Charlotte FL
i hope you like to type, or whatever.
Ch.FrequencyCh.FrequencyCh.FrequencyCh.FrequencyCh.Frequency
126.965 MHz927.065 MHz1727.165 MHz*2527.245 MHz3327.335 MHz
226.975 MHz1027.075 MHz1827.175 MHz2627.265 MHz3427.345 MHz
*326.985 MHz*1127.085 MHz*1927.185 MHz2727.275 MHz3527.355 MHz
427.005 MHz1227.105 MHz2027.205 MHz2827.285 MHz3627.365 MHz
527.015 MHz1327.115 MHz2127.215 MHz2927.295 MHz3727.375 MHz
627.025 MHz1427.125 MHz2227.225 MHz3027.305 MHz3827.385 MHz
*727.035 MHz*1527.135 MHz*2327.255 MHz3127.315 MHz3927.395 MHz
827.055 MHz1627.155 MHz*2427.235 MHz3227.325 MHz4027.405 MHz
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
Well given the fact the Pro 668 has no number pad it'd be a lot of arrowing up, down, left & right. Really tedious if you ask me. I'm sure it would take hours to button mash all 40 of them
link wont work
Works fine for me
wtp
Port Charlotte FL
PC Scanner Software Your scanner comes with an installed 2GB microSD card that contains the entire U.S.A/Canada RadioReference database as well as the iScan software. The simplest way to program your iScan is ZIP code, but for more advanced programming, the provided software lets you quickly customize your scanner from your computer. To install your iScan Software: 1. Connect the iScan to your PC using the supplied USB cable. An installation wizard should appear, or you can navigate to the microSD card and open setup.exe. 2. Follow the on-screen instructions to complete the installation. 3. When the software is installed, open the software and use the tabs to modify your settings and upload to your iScan. Refer to the online help for current information
it says the software is on the card !
